It is currently Thu Jul 17, 2025 9:52 pm
 Post subject: mando neck joint
PostPosted: Mon Apr 26, 2010 4:56 am
State: Serbia
hi,
I want to build my first mando...
it will be flat top, scale 361mm etc
where I nead some advice is about neck joint type in mando (some pic, or drawing or....)
regards
Fric
 Post subject: Re: mando neck joint
PostPosted: Mon Apr 26, 2010 8:43 am
First name: Big
Last Name: Jim
I usea a standard straight tennon joint as the pics show , These pics are NOT a finished tennon , but give you the basic idea . I use a long drywall screw from inside the box to pull it in tight while glue dries and when its done I remove the screw drill the hole out a little larger and glue a dowel in its place .
Keep in mind IM NOT A PRO !
This is just what works for me .
